I'm capturing VHS tapes using ADVC300 as Type 1 DV files. Type 1 DV files seems to fix audio video sync issues known to ADVC300.
MPCHC reports the files as Unknown [Stream 00]. Is this normal? The files play fine but AVISOURCE will not detect the audio. Maybe AVISOURCE will not work with Type 1 DV files. DIRECTSHOWSOURCE can create audio video sync issues if there are video hiccups. FFVIDEOSOURCE seems to be unable to or takes forever in opening large DV files (30+GB) even when I've made the index available using ffmsindex.exe.
I have to use VirtualDub and do direct stream copy for MPCHC to report the steams correctly and AVISOURCE to detect the audio. According to GSpot, VirtualDub export the files as Type 2 DV files.Code:General Format : AVI Format/Info : Audio Video Interleave Commercial name : DV Format profile : OpenDML File size : 9.42 GiB Duration : 46mn 45s Overall bit rate mode : Constant Overall bit rate : 28.9 Mbps Video ID : 0 Format : DV Duration : 46mn 45s Bit rate mode : Constant Bit rate : 24.4 Mbps Encoded bit rate : 28.8 Mbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 fps Standard : NTSC Chroma subsampling : 4:1:1 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 2.357 Time code of first frame : 17:47:08;10 Time code source : Subcode time code Stream size : 9.40 GiB (100%) Audio ID : 0-0 Format : PCM Muxing mode : DV Muxing mode, more info : Muxed in Video #1 Duration : 46mn 45s Bit rate mode : Constant Bit rate : 1 536 Kbps Encoded bit rate : 0 bps Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 514 MiB (5%) Encoded stream size : 0.00 Byte (0%)
Code:General Format : AVI Format/Info : Audio Video Interleave Commercial name : DV Format profile : OpenDML File size : 9.90 GiB Duration : 46mn 45s Overall bit rate mode : Constant Overall bit rate : 30.3 Mbps Writing library : VirtualDub build 33848/release Video ID : 0 Format : DV Codec ID : dvsd Codec ID/Hint : Sony Duration : 46mn 45s Bit rate mode : Constant Bit rate : 24.4 Mbps Encoded bit rate : 28.8 Mbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:1:1 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 2.357 Time code of first frame : 17:47:08;10 Time code source : Subcode time code Stream size : 9.40 GiB (95%) Audio ID : 1 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : 1 Duration : 46mn 45s Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 514 MiB (5%) Alignment : Aligned on interleaves Interleave, duration : 33 ms (1.00 video frame) Interleave, preload duration : 500 ms
Re: MPC-HC, dunno, can't check my other computer for DV files at the moment.
The incompatibility with Type-1 audio is noted in the AviSource documentation.
Maybe load video with AviSource and audio of AVI with FFAudio or other. -
you could just change from type 1 to type 2 - https://www.videohelp.com/software/DV-Type-1-to-DV-Type-2-Converter
In case you're not aware:
The DV data stream from the camcorder (or capture device) arrives at the computer with video and audio already multiplexed. When stored as a Type 1 DV AVI file the data is stored in a single stream in the AVI file -- marked as a video stream (even though it also contains audio). When stored as a Type 2 DV AVI, the audio is copied and stored as an additional stream -- an audio stream. So Type 1 files have only one stream marked as video, and Type 2 has two streams, one video and one audio.
Long ago, when computers were much slower, Type 1 made sense since it required less work while capturing. But since the audio is in the video stream software has be written specifically to handle the audio. AviSynth's AviSource() does not know how to access the audio from the video stream. It only gets the video. Many other programs have the same problem.
what type of stream is this
By adi10289 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Oct 2016, 12:06 -
Need help extracting video from unknown file type.
By Gallardo26 in forum Video ConversionReplies: 2Last Post: 31st Dec 2014, 07:12 -
No sound in winDV captures, DV-type 2
By brusno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 17th Jun 2013, 15:00 -
uncropMKV failing with unknown type error
By jaket4570 in forum Authoring (Blu-ray)Replies: 2Last Post: 24th Apr 2013, 23:00 -
"unknown parameters" when extracting TrueHD audio with Stream Extractor
By tony359 in forum Blu-ray RippingReplies: 0Last Post: 13th May 2012, 12:51
